Ir para o conteúdo principal
DeWalt DWE4011 Power Cable Replacement
kean colosimo
kean colosimo e 3 outros colaboradores
Última atualização em August 1, 2019
15 - 20 minutos
Fácil
When replacing electrical components on any device careful consideration must be taken to reduce risk of shock. Be sure the cord is not plugged into a power source before proceeding with this replacement guide. If the cord is cut, this should not be an issue. Reasons you might need follow this guide include: damaged power cord, or the grinder wont turn on.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. DeWalt DWE4011 Power Cable Replacement, Power Cord: passo 1, imagem 1 %32
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
  2. DeWalt DWE4011 Power Cable Replacement: passo 2, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 2, imagem 2 %32
    • Remove bottom casing by separating the end handle away from the main casing.
  3. DeWalt DWE4011 Power Cable Replacement: passo 3, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 3, imagem 2 %32
    • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
  4. DeWalt DWE4011 Power Cable Replacement: passo 4, imagem 1 %32
    • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
  5. DeWalt DWE4011 Power Cable Replacement: passo 5, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 5, imagem 2 %32
    • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
  6. DeWalt DWE4011 Power Cable Replacement: passo 6, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 6, imagem 2 %32
    • Locate the terminals with the two white cables attached and disconnect both.
    • These cables are connected to the outer terminals; connect as such during reassembly.
  7. DeWalt DWE4011 Power Cable Replacement: passo 7, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 7, imagem 2 %32
    • Remove the entirety of the cable housing from the device casing.
    • The two wires coming from the power cable should still be connected to electrical housing at this point.
  8. DeWalt DWE4011 Power Cable Replacement: passo 8, imagem 1 %32
    • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
    • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
Conclusão
4 outras pessoas executaram este guia.
Um comentário
Where can I find a replacement power cord?
Ethan Sligar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 42
Duração total: 3,721
