Ir para o conteúdo principal
DOSS SoundBox Motherboard Replacement
Cassandra Remsing
Cassandra Remsing e 6 outros colaboradores
Última atualização em May 7, 2024
35 minutos
Moderado
Introdução
Ir para o passo 1
This guide shows the necessary steps for removing the mother board from a DOSS SoundBox.
This motherboard controls the connection between Bluetooth and Auxiliary devices so signals transmitted by Bluetooth or Auxiliary can be processed and played over the loudspeakers. If the motherboard fails in the DOSS SoundBox, diagnostic symptoms can include static, intermittent connection issues or failure to play music.
Minimal knowledge is required for soldering as uninstalling the motherboard requires two contacts to be unsoldered.
There is also some adhesive holding the motherboard in place, so caution is recommended during removal to prevent breaks or cracks.
O que você precisa
Ferramentas
Exibir mais…
  1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, imagem 1 %32 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, imagem 2 %32 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, imagem 3 %32
    • Use a small plastic opening tool to gently lift the side of the grille.
    • Gently slide the tool to the front of the speaker.
    • Repeat the process on the bottom of the grille.
    • Gently pull the grille off of the speaker enclosure.
    • Pry with caution, for the grille is fragile.
  2. DOSS SoundBox Motherboard Replacement, Speaker: passo 2, imagem 1 %32 DOSS SoundBox Motherboard Replacement, Speaker: passo 2, imagem 2 %32
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  3. DOSS SoundBox Motherboard Replacement: passo 3, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 3, imagem 2 %32
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  4. DOSS SoundBox Motherboard Replacement: passo 4, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 4, imagem 2 %32
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
  5. DOSS SoundBox Motherboard Replacement, Battery: passo 5, imagem 1 %32 DOSS SoundBox Motherboard Replacement, Battery: passo 5, imagem 2 %32
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
  6. DOSS SoundBox Motherboard Replacement: passo 6, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 6, imagem 2 %32
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
  7. DOSS SoundBox Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
  8. DOSS SoundBox Motherboard Replacement: passo 8, imagem 1 %32
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
  9. DOSS SoundBox Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
    • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
    • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
    • Be sure not to apply excessive force on the ribbon connector, as it can break.
    • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
  10. DOSS SoundBox Motherboard Replacement: passo 10, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 10, imagem 2 %32
    • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
  11. DOSS SoundBox Motherboard Replacement: passo 11, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 11, imagem 2 %32 DOSS SoundBox Motherboard Replacement: passo 11, imagem 3 %32
    • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
    • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
    • Using your fingers, you can now remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
6Comentários do guia
Cassandra, the million dollar question is dWhere can i buy the motherboard for the SiundBox Doos.
please let me know at rubenalexander2611@hotmail.com, ahora todo lo mandan de la china please, a ver si me das una pagina web.
Ruben Diaz - Responder
As Cassandra said before,,,,WHere we can find the parts??? is it any possibilities ?
bunker1312@gmail.com
bunker1312 - Responder
Where to buy your motherboard for doss torch Bluetooth speaker
smoothjobbrian - Responder
Ffs, Where do you get the board? Pretty useless writeup if there's no known location to aquire parts.
Christopher Cox - Responder
I have taken the motherboard out. Where can I purchase another one as I don't see any link for that?
Paul Doran - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 34
Ao todo: 5,413
