DJI Mavic Pro Front Vision Replacement
Introdução
Ir para o passo 1This guide is for removing the DJI Mavic Pro Front Vision. To get to the front vision, you will need to remove the battery, upper shell, and gimbal first. In order to remove the gimbal in step 8, you will need to scrape some plastic adhesive off your device. Tweezers and three different sized screwdrivers are required for this guide.
O que você precisa
Grab both sides of the battery.
Pinch the releasing buttons on both sides of the battery.
Lift the battery up and out.
Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
Flip the drone over so that the gimbal is facing up.
Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
I must preface what I am about to say with this walk-through is amazing! Everything before and after this and the next step is spot-on!
There needs to be a step in-between this and the next.
UNDER THOSE CAPS ARE MORE SCREWS!!!I pretty much ruined the top case because I missed this and tried to muscle it open for about an hour. Just trying to warn the next.
Like I've said; this is an amazing walk-through
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the two small panel pieces near the gimbal case with the tweezers.
BEWARE! The two screws under the covers are not mentioned in step four to be removed, but they show that they have been removed in step five.
Step five should read- Remove the SIX 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
What he said!! ^^^
You might notice that there are two crosshead screws with larger heads (top two circled in image). You do NOT need to touch these as they are not part of the gimbal assembly.
Agree with @elfa1 - do not remove the top two screws, or you will put unnecessary strain on the plastic while moving arms. No need for that at all.
Flip the drone back over so the upper shell is facing up.
Pry off the upper shell with a nylon spudger.
using pry tool is not necessary - once all top shell screws are removed you should be able to take the top shell off with your hand.
Zudem fehlt hier die Angabe der genauen Lage von beiden vorderen Nasen:
Sie befinden sich von der Mitte aus gemessen jeweils 9mm nach links und rechts. Der obere Gehäuseteil wird von zwei 5mm breiten Bügeln gehalten, die unter die horizontal nach innen zeigenden Nasen vom unteren Gehäuseteil greifen.
Sorry “KopaZ Maymay”, but the plastic opener is “so necessary” because otherwise you unfortunately risk the two plastic noses in the front.
In addition, the exact position of both front noses is missing in the description:
They are measured 9mm from the center to the left and right. The upper part of the housing is held by two 5mm wide brackets that grip under the noses pointing horizontally inwards from the lower part of the housing.
Hi, is it a simple replacement. Ie you do not have to reprogram? Thanks
Remove the white connector at the back of the flight controller board by gently pulling at the base.
Hello there, can anyone tell me, please, what type of connector is this? I ruined mine and i like to fixit.
Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
what does this small board do? can i buy one as the 4 wires have come off mine
You do not need to unscrew compass to remove gimbal. This is unnecessary.
Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
Then, remove the two ZIF connectors under the coverings using a nylon spudger.
these plastic coverings were not present on my Mavic Pro. It’s a refurbished model so maybe it previously had a gimbal/camera replacement
I made a mistake - be careful that you remove the connectors closest to the front side of the drone which have a compound seal over the connector. The compound can be scratched away. I mistakenly thought it was the pair closer to the rear that has no compound covering them.
The front sensor screws (on light grey plastic) were removed on this photo. This is not needed to remove gimbal. Though it is worth mentioning that silicon glue can sometimes hold the gimbal assembly to that plastic, and may require some wiggle or gentle removal of part of the silicon to detach.
Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
Flip the DJI Mavic Pro back over, with its top side facing up.
Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
the two screws pictured here, between the top set of connectors and the bottom set of connectors appears in place here. But in the following step the screws are removed. Why were the screws removed? Was this to replace the gimbal circuit board?
oops, these are removed in Step 11
Tip: During reassembly go ahead and complete step 11 early, this will ensure the gimbal is properly seated so you don't have issues with the connectors being too far down in the housing.
Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
Was ist das für eine Klebemasse, mit denen die Schrauben respektive Connectoren befestigt werden sollten?
Kennt jemand ein Fabrik und/oder Bezugsquelle?
Flip the DJI Mavic Pro over, with the camera facing you.
Gently pull the gimbal/camera assembly up and out.
There's a little plastic piece on mine that is broken off behind and the platform of the camera that looks like it almost helps secure it down any idea what that would be called? Does the front camera sensor piece support the gimble and camera in any way physically?
Remove the front vision piece by pulling the piece up and away from the drone body.
Where can you find this to buy and replace?
8 outras pessoas executaram este guia.
4Comentários do guia
What error codes did you get before having to replace this front cameras?
la nacelle de mon drone mavic pro ne fais aucun mouvement quand je l'allume s'il vous plaît quel pourrait être le problème ?
Picharkayo@gmail.com
I have error of forward motion isn’t recognizing how can I fix it please help
'lamao
Max Poerner - Responder
