Ir para o conteúdo principal
Crosley CR704 Control Knobs Replacement
MarkAnthony
MarkAnthony e 3 outros colaboradores
Última atualização em August 1, 2019
1 minuto
Muito fácil
Imagens inconsistentes
Introdução
Ir para o passo 1
Control knobs are available in a wide variety of shapes, sizes, and materials and are used for various applications and come or can be designed in many configurations including instrument, pointer, skirted, large fluted with skirt, soft touch, and illuminated. Your replacement control knob should fit over a 6mm peg.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  1. Crosley CR704 Control Knobs Replacement, Safety: passo 1, imagem 1 %32
    • Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
    • Make sure the turntable cover is closed so that nothing jostles out of place.
  2. Crosley CR704 Control Knobs Replacement: passo 2, imagem 1 %32
    • Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
    • With some force, pry the knob off of its peg.
    • The knob should slide off smoothly, but beware of flying knobs!
  3. Crosley CR704 Control Knobs Replacement: passo 3, imagem 1 %32
    • Applying some force, insert the replacement knob onto the peg.
Conclusão
Test by turning on your radio and playing a tune. We suggest "Last Dance" by Dona Summer.
MarkAnthony
Membro desde: 09/22/13
772 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Membro de UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 1,901
