Ir para o conteúdo principal
Cricut Maker 3 Top Cover Replacement
Spencer Pennington
Spencer Pennington
Última atualização em 31 de jul de 2025
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
Follow this guide to replace the top cover in your Cricut Maker 3.
If the top cover is cracked or loose, it may need to be replaced.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Cricut Maker 3 Top Cover Replacement, Prepare your Cricut for disassembly: passo 1, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Prepare your Cricut for disassembly: passo 1, imagem 2 %32 Cricut Maker 3 Top Cover Replacement, Prepare your Cricut for disassembly: passo 1, imagem 3 %32
    • Be very careful not to cut yourself when working near the Cricut's small, sharp blade, located in the tool holder within the Cricut.
    • Power off the Cricut and unplug all cables.
  2. Cricut Maker 3 Top Cover Replacement, Remove the rubber feet: passo 2, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Remove the rubber feet: passo 2, imagem 2 %32 Cricut Maker 3 Top Cover Replacement, Remove the rubber feet: passo 2, imagem 3 %32
    • Flip the Cricut over so the bottom is facing up.
    • Use your finger to pry up and remove all four rubber feet from the bottom of the Cricut.
  3. Cricut Maker 3 Top Cover Replacement, Remove the screws from the base: passo 3, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Remove the screws from the base: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the four 41 mm‑long screws securing the top cover to the base. There's one screw under each foot.
  4. Cricut Maker 3 Top Cover Replacement, Open the Cricut: passo 4, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Open the Cricut: passo 4, imagem 2 %32
    • Flip the Cricut over so the silver lid is facing up.
    • You may replace the rubber feet before flipping your Cricut to avoid damaging the Cricut or your work surface.
    • Open the Cricut by lifting the top silver lid. The front tray will also open.
  5. Cricut Maker 3 Top Cover Replacement, Remove the screws from the metal track: passo 5, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Remove the screws from the metal track: passo 5, imagem 2 %32 Cricut Maker 3 Top Cover Replacement, Remove the screws from the metal track: passo 5, imagem 3 %32
    • Inside the Cricut are seven screws securing the top cover to the metal track that guides the tool holder. You can reach these screws by putting a screwdriver bit in a ratcheting socket wrench. If you're using iFixit bits, the smaller bits work with a 4‑mm socket and the larger bits work with a 1/4‑inch socket.
    • Remove the seven 9.8 mm‑long Phillips screws securing the top cover to the metal track.
  6. Cricut Maker 3 Top Cover Replacement, Remove the lid hinge cover: passo 6, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Remove the lid hinge cover: passo 6, imagem 2 %32
    • The lid hinge cover is located at the base of the silver lid and is held in place by five pegs which are lightly glued in place.
    • Insert the flat end of a spudger between the right side of the lid hinge cover and the top cover.
    • If there's not enough space to insert a spudger, push the silver lid to the left.
    • Use the spudger to pry up the cover.
    • Firmly pry near the pegs to avoid cracking the cover.
  7. Cricut Maker 3 Top Cover Replacement: passo 7, imagem 1 %32 Cricut Maker 3 Top Cover Replacement: passo 7, imagem 2 %32 Cricut Maker 3 Top Cover Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry up along the long edge of the lid hinge cover until the cover is free.
  8. Cricut Maker 3 Top Cover Replacement: passo 8, imagem 1 %32 Cricut Maker 3 Top Cover Replacement: passo 8, imagem 2 %32
    • Lift and remove the lid hinge cover.
  9. Cricut Maker 3 Top Cover Replacement, Remove the lid screws: passo 9, imagem 1 %32
    • Use a Torx T8 screwdriver to remove the four 10.2 mm‑long screws securing the lid to the hinge.
  10. Cricut Maker 3 Top Cover Replacement, Remove the lid: passo 10, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Remove the lid: passo 10, imagem 2 %32
    • Use the flat end of spudger to pry the lid out of the hinge while lifting the lid.
  11. Cricut Maker 3 Top Cover Replacement: passo 11, imagem 1 %32 Cricut Maker 3 Top Cover Replacement: passo 11, imagem 2 %32
  12. Cricut Maker 3 Top Cover Replacement, Lift the top cover: passo 12, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Lift the top cover: passo 12, imagem 2 %32
    • There's still a cable connected to the inside of the top cover. Don't attempt to fully remove the top cover yet.
    • Lift the top cover up from the Cricut just until it comes free of the base.
  13. Cricut Maker 3 Top Cover Replacement: passo 13, imagem 1 %32 Cricut Maker 3 Top Cover Replacement: passo 13, imagem 2 %32 Cricut Maker 3 Top Cover Replacement: passo 13, imagem 3 %32
    • Rotate the top cover to the right and prop it up so the right side of the cover is resting on your work surface.
  14. Cricut Maker 3 Top Cover Replacement, Disconnect the button board: passo 14, imagem 1 %32 Cricut Maker 3 Top Cover Replacement, Disconnect the button board: passo 14, imagem 2 %32
  15. Cricut Maker 3 Top Cover Replacement: passo 15, imagem 1 %32 Cricut Maker 3 Top Cover Replacement: passo 15, imagem 2 %32
    • Peel up the tape securing the button wires to the inside of the top cover.
    • During reassembly, if this tape isn't sticking well, replace it with a piece of electrical tape to make sure these wires don't get caught in the gears.
  16. Cricut Maker 3 Top Cover Replacement, Remove the top cover: passo 16, imagem 1 %32
    • Lift and remove the top cover.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Spencer Pennington
Membro desde: 09/09/23
21.163 Reputação
Autoria de 116 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 23.084 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 115
Ao todo: 713
