Ir para o conteúdo principal
Craftsman Model 315.10721 Table Guard Replacement
Riley Hilliker
Riley Hilliker e 4 outros colaboradores
Última atualização em December 19, 2014
25 - 30 minutos
Moderado
Introdução
Ir para o passo 1
The table guard is essential in making sure the Craftsman Model 315.10721 makes the desired cuts. Keep in mind when performing the replacement that disassembling the table guard is time consuming.
O que você precisa
Ferramentas
Exibir mais…
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: passo 1, imagem 1 %32
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: passo 2, imagem 1 %32
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: passo 3, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: passo 4, imagem 1 %32
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Conclusão
Uma outra pessoa concluiu este guia.
Riley Hilliker
Membro desde: 10/14/14
557 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-47, Amido Fall 2014 Membro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membros
Autoria de 5 guias
2Comentários do guia
Where can I get a replacement table guard???
Roger Coyle - Responder
Where can I get a replacement table guard for this jig saw????????
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 686
