Conair Cord-Keeper 169XR On/Off Switch Replacement
Introdução
Vá para o passo 1If your Conair Cord-Keeper 169XR dryer isn't turning on, the back of the On/Off button that engages the power may be broken.
O que você precisa
Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
Once the new switch is in place you can put the dryer back together.
3 outras pessoas executaram este guia.
3 comentários
Looks to me that a replacement switch would be required. How can obtain one?
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
That was my question, where can I get a replacement switch?
