Chef's Choice M115 Sharpening Stones Replacement
Introdução
Vá para o passo 1Sharpening is essentially what the chef's choice is about. This is achieved by the sharpening stones and will frequently need to be replaced. Extra caution to be taken on the removal of the c-clips as they can easily spring out and get lost.
O que você precisa
Ferramentas
Exibir mais…
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
With the outer case removed, firmly grasp the motor-axle attachment and remove it from the base. It should come right off of the assembly.
5 comentários
where does one get the replacement stones. im not seeing they in my amazon/google searches. also cant seem to see them on manufacturers website section for parts.
I have the same question.
same question, where do I order replacement stones ?? I have the chef’s choice Sportsman from cabelas, thanks in advance .. you can send any info to my e-mail thebobster@ns.sympatico.ca any info wiuld be greatly appreciated..
**Same question. Where do I purchase sharpener replacements.
=on research,
Chef's-Choice customer Support indicated 'no serviceable parts inside /or provided', return the sharpener to manufacturer for an evaluation 'repair cost estimate". They do not give estimates on any work or the wheels, they need to have it in hand in their service department for an 'estimate' on repairs.
~therefore appears
no Chef's-choice sharpeners have replacement service parts available or service documentation available to the customer.
Having opened one up and examined the one I have,
^DIY ?
...a fine-Gd quality diamond/emery paper and a Gd-quality adhesive from a hardware is your options unless you want to return it to them.
Though I was thinking a small cutting wheel of same shape size for a refit, saw a collection of sizes when at harbor-f week or so ago but thik to course an app
..Follow Up
(Just for yucks tried contacted chef- on return mine for 'service evaluation', no return to me email_call_text, disposable?, Lol) out of t
