Chef's Choice M115 Power Switch Replacement
Introdução
Ir para o passo 1A loose or faulty power switch should be replaced immediately. This can be a fire hazard due to an electrical short or choking hazard if it got loose and fell into the hands of an infant. This guide will show you how to prevent this from happening.
O que você precisa
Ferramentas
Exibir mais…
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
Um comentário
What kind of switch should I replace the bad switch with? Is there one on Amazon ?
