Ir para o conteúdo principal
Canon PowerShot SX160 IS Function Wheel Replacement
Jamie Secretan
Jamie Secretan e um outro colaborador
Última atualização em June 22, 2015
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
This guide provides a breakdown that shows how to replace the function wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the function wheel.
O que você precisa
Ferramentas
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: passo 1, imagem 1 %32 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: passo 1, imagem 2 %32 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: passo 1, imagem 3 %32
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: passo 2, imagem 1 %32 Canon PowerShot SX160 IS Function Wheel Replacement: passo 2, imagem 2 %32
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: passo 3, imagem 1 %32 Canon PowerShot SX160 IS Function Wheel Replacement: passo 3, imagem 2 %32
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: passo 4, imagem 1 %32
    • Remove and replace the function wheel.
Conclusão
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Membro desde: 03/11/15
1.990 Reputação
Autoria de 6 guias
Equipe
1Comentário do guia
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 635
