Ir para o conteúdo principal
Canon PowerShot SD850 IS Camera Lens Replacement
Peter Tran
Peter Tran e 2 outros colaboradores
Última atualização em February 19, 2016
30 - 35 minutos
Moderado
Fotos de ação
Imagens inconsistentes
Faltando Passos
Introdução
Ir para o passo 1
Use this guide to remove a broken camera lens from your Canon PowerShot SD850 IS.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon PowerShot SD850 IS Camera Lens Replacement, Case: passo 1, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement, Case: passo 1, imagem 2 %32
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  2. Canon PowerShot SD850 IS Camera Lens Replacement: passo 2, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 2, imagem 2 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 2, imagem 3 %32
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  3. Canon PowerShot SD850 IS Camera Lens Replacement: passo 3, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 3, imagem 2 %32
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  4. Canon PowerShot SD850 IS Camera Lens Replacement: passo 4, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 4, imagem 2 %32
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  5. Canon PowerShot SD850 IS Camera Lens Replacement: passo 5, imagem 1 %32
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  6. Canon PowerShot SD850 IS Camera Lens Replacement: passo 6, imagem 1 %32
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  7. Canon PowerShot SD850 IS Camera Lens Replacement, LCD Screen: passo 7, imagem 1 %32
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  8. Canon PowerShot SD850 IS Camera Lens Replacement: passo 8, imagem 1 %32
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  9. Canon PowerShot SD850 IS Camera Lens Replacement: passo 9, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 9, imagem 2 %32
    • Remove the two metal frames that hold the LCD panel in place.
  10. Canon PowerShot SD850 IS Camera Lens Replacement: passo 10, imagem 1 %32
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    When reassembling the camera, the tab that gets flipped up to release the cable will not lock back down into place after the cable is reinserted.
    Schu - Responder
  11. Canon PowerShot SD850 IS Camera Lens Replacement: passo 11, imagem 1 %32
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
    How to unlock the backlight cable is not at all clear. This also leads to a problem with how to reinsert and lock the cable while putting the camera back together.
    Schu - Responder
  12. Canon PowerShot SD850 IS Camera Lens Replacement: passo 12, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 12, imagem 2 %32
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD850 IS Camera Lens Replacement, Flash Unit: passo 13, imagem 1 %32
    • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
  14. Canon PowerShot SD850 IS Camera Lens Replacement: passo 14, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 14, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
    • Next use the tweezers to carefully remove the speaker cable off its respective holders.
  15. Canon PowerShot SD850 IS Camera Lens Replacement: passo 15, imagem 1 %32
    • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
  16. Canon PowerShot SD850 IS Camera Lens Replacement: passo 16, imagem 1 %32 Canon PowerShot SD850 IS Camera Lens Replacement: passo 16, imagem 2 %32
    • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
    • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
  17. Canon PowerShot SD850 IS Camera Lens Replacement: passo 17, imagem 1 %32
    • Gently remove the flash component from the rest of the camera.
    • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
  18. Canon PowerShot SD850 IS Camera Lens Replacement, Camera Lens: passo 18, imagem 1 %32
    • Remove four screws located on the back of the camera:
    • 6.15 mm #00 Phillips
    • 2.75 mm #00 Phillips
    • 2.15 mm #00 Phillips
    • 2.7 mm #00 Phillips
  19. Canon PowerShot SD850 IS Camera Lens Replacement: passo 19, imagem 1 %32
    • Use a spudger or a flathead screwdriver and carefully pry out the bulb located in the front of the camera on top of the camera lens.
  20. Canon PowerShot SD850 IS Camera Lens Replacement: passo 20, imagem 1 %32
    • Gently remove the camera lens from the rest of the camera.
Conclusão
3 outras pessoas executaram este guia.
Peter Tran
Membro desde: 10/06/10
252 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-7, Maness Fall 2010 Membro de Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Membros
Autoria de 7 guias
2Comentários do guia
If you have a problem on your camera then it is better if you go nearest technician to fix your camera.
Get a good action camera at http://actionshotcam.com
Jerome Tenedero - Responder
step 10 was very unclear, the dark brown part of the cable connector is what is supposed to be lifted. i tried to lift the black part, as the guide stated, and broke off the data cable connector rendering my camera nearly useless
Felix - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 14,441
