Canon PowerShot G12 LCD Screen Replacement
Introdução
Ir para o passo 1Replacing the LCD screen is a highly-invasive, step-intensive process that becomes necessary if the screen has sustained damage to due a crack, water, or an otherwise internal malfunction.
In this guide, you will learn how to replace the LCD screen carefully.
O que você precisa
Peças
Ferramentas
Exibir mais…
Flip the LCD screen vertically and remove the final screws on the outer edge of the screen with the same Phillips-head 00 screwdriver. All screws have Loctite (blue) on them so they a difficult to turn. Make sure your Phillips screw driver fits perfectly. Sometimes a new screwdriver will need to have the tip filed down a little to fit.
Place the new LCD screen into the metal shell with the yellow connector tab facing outward.
Connect the new screen with the green circuit board ensuring you use the tweezers to connect it fully into the port.
Many steps were left out here in this tutorial, especially removing the broken LCD display from its metal case. Try YouTube German video at https://www.youtube.com/watch?v=ZNx2ylpj... from http://www.kamera-station.de. This video shows the complete disassembly and reassembly process, although it's in German. You can at least see the process by pausing and replaying the video. I could not find an English video. Richard Taylor, Elizabeth City, NC, 10/22/2016.
3 outras pessoas executaram este guia.
