Canon PowerShot ELPH 150 IS LCD Screen Replacement
Introdução
Ir para o passo 1This guide will give clear instruction that allows you to replace your camera's LCD screen if it has become cracked or damaged.
O que você precisa
Ferramentas
Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
Once the back plate and face plate have been removed, you can begin to remove the LCD screen.
Gently remove the silver plate by pulling it back towards you as you hold the camera firmly in the other hand.
With the plate removed you will be able to locate the electrical ribbon that connect the LCD screen to the device.
You will also be able to lift the LCD screen away from the motherboard cover as picture in image 3. It will still be attached via electrical ribbon but can be moved to the side so you can access the clip underneath.
Gear Up For Future Repairs
Shop all1Comentário do guia
Great tutorial! Where can I buy the screen? I contacted Canon and they said they don't sell these parts; they just replace the cameras that are sent in with broken screens.
