Ir para o conteúdo principal
Canon PowerShot ELPH 150 IS LCD Screen Replacement
Alex Larrimore
Alex Larrimore e 2 outros colaboradores
Última atualização em May 17, 2017
10 - 15 minutos
Moderado
Acidente de Marcação
Introdução
Ir para o passo 1
This guide will give clear instruction that allows you to replace your camera's LCD screen if it has become cracked or damaged.
O que você precisa
Ferramentas
  1. Canon PowerShot ELPH 150 IS LCD Screen Replacement, Back Plate/Menu Buttons: passo 1, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement, Back Plate/Menu Buttons: passo 1, imagem 2 %32
    • Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 2, imagem 1 %32
    • Locate the back plate of the camera (contains the LCD screen and menu buttons).
  3. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 3, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 3, imagem 2 %32
    • To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
    • Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
  4. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 4, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 4, imagem 2 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 4, imagem 3 %32
    • Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 5, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
  6. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 6, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 6, imagem 2 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 6, imagem 3 %32
    • Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
    • Completely remove the back plate.
  7. Canon PowerShot ELPH 150 IS LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32
    • Once the back plate and face plate have been removed, you can begin to remove the LCD screen.
  8. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 8, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 8, imagem 2 %32
    • Turn the camera so that the LCD screen is facing you.
    • Remove the 2 screws on the silver plate to the right of the screen using the PH00 screw driver head.
  9. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 9, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 9, imagem 2 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 9, imagem 3 %32
    • Gently remove the silver plate by pulling it back towards you as you hold the camera firmly in the other hand.
    • With the plate removed you will be able to locate the electrical ribbon that connect the LCD screen to the device.
    • You will also be able to lift the LCD screen away from the motherboard cover as picture in image 3. It will still be attached via electrical ribbon but can be moved to the side so you can access the clip underneath.
  10. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 10, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 10, imagem 2 %32
    • With the screen off to the side, and the horizontal electrical ribbon attached to it out of the way, gently lift the vertical electrical transducer ribbon to expose the salmon colored clip holding the horizontal ribbon in place.
  11. Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 11, imagem 1 %32 Canon PowerShot ELPH 150 IS LCD Screen Replacement: passo 11, imagem 2 %32
    • Pull the clip away from the horizontal electrical ribbon to unlock it.
    • Gently pull the horizontal electrical ribbon out of the clip to remove the LCD screen completely. Go slowly so you do no rip the ribbon or damage the clip or exposed motherboard beneath it.
Conclusão
Alex Larrimore
Membro desde: 03/05/17
305 Reputação
Autoria de 3 guias
Equipe
1Comentário do guia
Great tutorial! Where can I buy the screen? I contacted Canon and they said they don't sell these parts; they just replace the cameras that are sent in with broken screens.
gravity1015 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 48
Ao todo: 1,631
