Ir para o conteúdo principal
Canon PowerShot A80 LCD Screen Replacement
konrad
konrad e 15 outros colaboradores
Última atualização em 9 de jan de 2025
20 - 40 minutos
Moderado
Fotos de ação
Introdução
Ir para o passo 1
Is your Canon PowerShot A80’s LCD screen blurry, cracked, or failing to display images? This guide walks you through replacing the faulty screen so your camera can function like new. A broken LCD makes it tough to focus on your subjects or navigate settings.
Important: Before starting, turn off the camera and remove the battery to avoid electric shock or damage. If you're unsure whether the screen is the issue, visit our troubleshooting page for more help.
O que você precisa
Ferramentas
  1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
  2. Canon PowerShot A80 LCD Screen Replacement: passo 2, imagem 1 %32 Canon PowerShot A80 LCD Screen Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
    • To access the second screw, rotate the screen 90° so that it faces upwards.
  3. Canon PowerShot A80 LCD Screen Replacement: passo 3, imagem 1 %32 Canon PowerShot A80 LCD Screen Replacement: passo 3, imagem 2 %32 Canon PowerShot A80 LCD Screen Replacement: passo 3, imagem 3 %32
    • Gently remove the front and back covers from the screen.
    • Peel back the plastic circuit cover.
  4. Canon PowerShot A80 LCD Screen Replacement: passo 4, imagem 1 %32
    • Pull the screen away from the base.
    • This will take some force, but remember to handle with care.
    • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
  5. Canon PowerShot A80 LCD Screen Replacement: passo 5, imagem 1 %32
    • Unplug the ribbon cable connected to the circuit board latch.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
konrad
Membro desde: 01/11/11
220 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-31, Regan Winter 2011 Membro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Membros
Autoria de 12 guias
1Comentário do guia
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 29
Ao todo: 4,497
