Ir para o conteúdo principal
Canon EOS Rebel T3 Front Cover Replacement
Zephosk
Zephosk e um outro colaborador
Última atualização em January 3, 2025
15 minutos
Moderado
Guia colaborativo
This guide shows you how to remove the front cover if you either need to replace the cover, or in order to access other parts inside of the camera.
If you're replacing, the front covers for the Canon EOS Rebel T3, Canon EOS Kiss X50, and Canon EOS 1100D are all compatible with each other (since they are all the same camera, just rebranded for different countries). If you buy a front cover that has a name plate that has one of the other model names than the camera you have, you can always switch it out from the one from your broken front cover (it's held on with adhesive). Front cover replacement parts won't always include a name plate though.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon EOS Rebel T3 Front Cover Replacement, I/F Terminal Cover: passo 1, imagem 1 %32 Canon EOS Rebel T3 Front Cover Replacement, I/F Terminal Cover: passo 1, imagem 2 %32 Canon EOS Rebel T3 Front Cover Replacement, I/F Terminal Cover: passo 1, imagem 3 %32
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Front Cover Replacement, Back Cover: passo 2, imagem 1 %32 Canon EOS Rebel T3 Front Cover Replacement, Back Cover: passo 2, imagem 2 %32
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Front Cover Replacement: passo 3, imagem 1 %32 Canon EOS Rebel T3 Front Cover Replacement: passo 3, imagem 2 %32
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Front Cover Replacement: passo 4, imagem 1 %32 Canon EOS Rebel T3 Front Cover Replacement: passo 4, imagem 2 %32 Canon EOS Rebel T3 Front Cover Replacement: passo 4, imagem 3 %32
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
  5. Canon EOS Rebel T3 Front Cover Replacement, Front Cover: passo 5, imagem 1 %32
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T3 Front Cover Replacement: passo 6, imagem 1 %32
    • On the bottom of the camera, remove the following screws:
  7. Canon EOS Rebel T3 Front Cover Replacement: passo 7, imagem 1 %32 Canon EOS Rebel T3 Front Cover Replacement: passo 7, imagem 2 %32 Canon EOS Rebel T3 Front Cover Replacement: passo 7, imagem 3 %32
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
Conclusão
Documentos anexados
Zephosk
Membro desde: 09/26/24
4.558 Reputação
Autoria de 29 guias
Equipe
LGBTQ Technicians Membro de LGBTQ Technicians
Community
34 Membros
Autoria de 98 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 50
