Canon EOS 40D Date and Time Battery Replacement
Introdução
Ir para o passo 1If your date and time battery needs to be replaced, follow this guide to replace it. The required date and time battery is a CR2016 lithium.
O que você precisa
Locate the battery compartment cover on the bottom of the camera below the shutter button.
Remove the date and time battery holder by sliding it out of the slot.
9 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all6Comentários do guia
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Great help! Accurate, easy to follow directions
