Ir para o conteúdo principal
Brother Boutique 761 Needle Replacement
Erin Juarez
Erin Juarez e 2 outros colaboradores
Última atualização em February 28, 2025
10 minutos
Moderada
Whether you're a beginner or an experienced at sewing it's essential to know how to properly install a needle to ensure smooth and accurate stitching. Here's a step-by-step guide on how to fix a needle on a sewing machine.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Brother Boutique 761 Needle Replacement, Needle: passo 1, imagem 1 %32 Brother Boutique 761 Needle Replacement, Needle: passo 1, imagem 2 %32
    • Locate the screw and turn the screw counterclockwise (left).
    • Loosen the screw gently and carefully remove the needle.
  2. Brother Boutique 761 Needle Replacement: passo 2, imagem 1 %32
    • Remove the faulty needle and replace it with a new needle.
  3. Brother Boutique 761 Needle Replacement: passo 3, imagem 1 %32
    • Take the new needle, place the needle carefully at the base of the opening.
    • Secure the new needle, locate the screw and turn it clockwise (right) until tightened.
  4. Brother Boutique 761 Needle Replacement: passo 4, imagem 1 %32 Brother Boutique 761 Needle Replacement: passo 4, imagem 2 %32
    • Secure the needle once again. We will start to re-thread the sewing machine.
    • Place the thread on the lever with the loose piece of thread on the outside.
  5. Brother Boutique 761 Needle Replacement: passo 5, imagem 1 %32
    • Take the loose piece of thread and place it through the hood that is present at the top of the sewing machine.
  6. Brother Boutique 761 Needle Replacement: passo 6, imagem 1 %32
    • Pull the thread down towards you in the open on the front of your machine.
    • Hook the thread at the end of the opening.
  7. Brother Boutique 761 Needle Replacement: passo 7, imagem 1 %32
    • Take your thread and locate the hole that is in the needle.
    • Put the thread through the hole.
  8. Brother Boutique 761 Needle Replacement: passo 8, imagem 1 %32
    • Make sure that the thread is through the needle. Pull the thread down underneath the presser foot.
    • You have now finished replacing the needle and rethreading the sewing machine.
Conclusão
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
Erin Juarez
Membro desde: 10/23/23
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 22
Duração total: 329
