Ir para o conteúdo principal
BLU Vivo One Plus Battery Replacement
Keely Mashburn
Keely Mashburn e 2 outros colaboradores
Última atualização em December 12, 2019
40 - 45 minutos
Difícil
Precisa de melhores imagens
Repower your device by changing its battery. This guide instructs you how to remove the back of the phone and access the battery to safely remove it. If your battery is not performing to the level that you expect of it or if you simply would like to replace it, this guide will show you how to do that. It is a bit more difficult than previous BLU models but with some tools and time you can get it done.
O que você precisa
Ferramentas
Exibir mais…
  1. BLU Vivo One Plus Battery Replacement, Battery: passo 1, imagem 1 %32 BLU Vivo One Plus Battery Replacement, Battery: passo 1, imagem 2 %32 BLU Vivo One Plus Battery Replacement, Battery: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    SIM Card Eject Tool
    $2.99
  2. BLU Vivo One Plus Battery Replacement: passo 2, imagem 1 %32 BLU Vivo One Plus Battery Replacement: passo 2, imagem 2 %32 BLU Vivo One Plus Battery Replacement: passo 2, imagem 3 %32
    iFixit Opening Tool
    $1.99
    • Use the plastic opening tool and run it under the entire seam that separates the screen and the plastic back of the phone.
    • Lodge the plastic opening tool under the back cover and use it to pry the two parts apart slowly.
    • This step will take a decent amount of force and it may seem as though the device will fracture, but you must keep pulling until the back releases.
  3. BLU Vivo One Plus Battery Replacement: passo 3, imagem 1 %32 BLU Vivo One Plus Battery Replacement: passo 3, imagem 2 %32
    Phillips #000 Screwdriver
    $5.49
    • Using a Phillips 000 screwdriver, remove the 14 1.5 mm screws that attach the plastic protection cover to the phone.
    • Removing the screws will cause a silver metal bracket by the top left corner of the battery to fall off. Keep track of it for later.
  4. BLU Vivo One Plus Battery Replacement: passo 4, imagem 1 %32 BLU Vivo One Plus Battery Replacement: passo 4, imagem 2 %32
    Spudger
    $3.99
    • After removing the screws, the bottom plastic cover will need to be removed to expose the rest of the phone’s interior.
    • The plastic cover should come off easily using your fingers, but you may need the spudger or an opening pick to remove it.
    • Remove the cover by its sides to ensure the removal is as easy as possible.
  5. BLU Vivo One Plus Battery Replacement: passo 5, imagem 1 %32 BLU Vivo One Plus Battery Replacement: passo 5, imagem 2 %32
    iFixit Opening Picks (Set of 6)
    • Remove the two blue strips of tape on the lower portion of the battery.
    • After removing the blue strips of tape gently begin wedging the plastic picks underneath the battery and locating the adhesive tape strips.
    • Utilize the picks in a fashion that both pries the battery upward and scrapes the adhesive either loose from the battery or phone body. Be careful not to bend or damage the battery and it should eventually come free from the housing.
  6. BLU Vivo One Plus Battery Replacement: passo 6, imagem 1 %32 BLU Vivo One Plus Battery Replacement: passo 6, imagem 2 %32
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 2,169
