Ir para o conteúdo principal
BLU Vivo 5 Mini Speaker Replacement
Kymari
Kymari e 4 outros colaboradores
Última atualização em May 7, 2024
20 minutos
Moderada
Use this guide to replace muffled speaker/ sound issues.
Complete the prerequisite before starting.
For better sound make sure volume settings are turned to desired loudness.
Use this guide to also check for water damage before replacement.
O que você precisa
Ferramentas
Exibir mais…
  1. BLU Vivo 5 Mini Speaker Replacement, Back Cover: passo 1, imagem 1 %32 BLU Vivo 5 Mini Speaker Replacement, Back Cover: passo 1, imagem 2 %32 BLU Vivo 5 Mini Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Speaker Replacement: passo 2, imagem 1 %32 BLU Vivo 5 Mini Speaker Replacement: passo 2, imagem 2 %32 BLU Vivo 5 Mini Speaker Replacement: passo 2, imagem 3 %32
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Speaker Replacement: passo 3, imagem 1 %32 BLU Vivo 5 Mini Speaker Replacement: passo 3, imagem 2 %32 BLU Vivo 5 Mini Speaker Replacement: passo 3, imagem 3 %32
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Speaker Replacement: passo 4, imagem 1 %32 BLU Vivo 5 Mini Speaker Replacement: passo 4, imagem 2 %32 BLU Vivo 5 Mini Speaker Replacement: passo 4, imagem 3 %32
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
  5. BLU Vivo 5 Mini Speaker Replacement, Speaker: passo 5, imagem 1 %32 BLU Vivo 5 Mini Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Slide the spudger between the speaker covers (might be held down with adhesive stickiness.)
    • Use the PH000 screwdriver to remove any leftover screws near bottom of the device.
  6. BLU Vivo 5 Mini Speaker Replacement: passo 6, imagem 1 %32
    • Gently slide the pick between the black sound motherboard (located under the battery.)
    • Use the tweezers to lift speaker motherboard out of device.
  7. BLU Vivo 5 Mini Speaker Replacement: passo 7, imagem 1 %32
    • After checking for debris and water surrounding the speaker area, replace with new speaker.
Conclusão
3 outras pessoas executaram este guia.
Kymari
Membro desde: 10/09/18
725 Reputação
Autoria de 5 guias
Equipe
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 234
