Ir para o conteúdo principal
BLU Energy X Battery Replacement
Sishun Wang
Sishun Wang e 3 outros colaboradores
Última atualização em August 4, 2016
5 minutos
Fácil
Introdução
Ir para o passo 1
In this guide the user will have to open the back of the phone and remove the top pate to expose the battery connection to the motherboard. Because the battery is not supposed to be removed, there is an adhesive on the back of the battery that makes it difficult to remove from the phone. The metal spudger is the best tool to use to pry the battery from the phone body.
O que você precisa
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. BLU Energy X Battery Replacement, Battery: passo 1, imagem 1 %32 BLU Energy X Battery Replacement, Battery: passo 1, imagem 2 %32 BLU Energy X Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Battery Replacement: passo 2, imagem 1 %32 BLU Energy X Battery Replacement: passo 2, imagem 2 %32
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Battery Replacement: passo 3, imagem 1 %32 BLU Energy X Battery Replacement: passo 3, imagem 2 %32 BLU Energy X Battery Replacement: passo 3, imagem 3 %32
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
Conclusão
4 outras pessoas executaram este guia.
Sishun Wang
Membro desde: 02/08/16
630 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-2, Eyestone Spring 2016 Membro de USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 Membros
Autoria de 5 guias
2Comentários do guia
Hi. I my short Band Aid q makes connection between the battery and cell .. q do ? They are fixable ?
tamara diale - Responder
directions were pretty straightforward... mine had a tiny sticker w/ the "B" in BLU printed, covering the screw on the upper left corner that needed removal (warranty?). otherwise, simple replacement...thanks!
joe doe (ch555x) - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 2,041
