Ir para o conteúdo principal
Asus Vivobook F510UA Hard Drive Replacement
Deandre Mendes
Deandre Mendes e 4 outros colaboradores
Última atualização em July 5, 2024
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
This guide will show you how to replace the hard drive in an Asus Vivobook F510UA laptop. The hard drive is a piece of hardware that stores and retrieves data in your computer. A failing hard drive can cause your laptop to produce irregular noises and/or continuous crashes and error messages like “file not found” or “Windows detected a hard disk problem.” In some cases, your computer may not boot at all if it experiences hard drive failure.
If possible, make sure you back up the data on your hard drive before attempting to replace it to ensure that you do not lose any valuable data. Your device should be powered off completely and disconnected from any external power source before beginning the replacement process.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Asus Vivobook F510UA Hard Drive Replacement, Removing the bottom panel: passo 1, imagem 1 %32 Asus Vivobook F510UA Hard Drive Replacement, Removing the bottom panel: passo 1, imagem 2 %32
    • Turn your laptop so that the back panel is facing you.
    • Remove the large gray rubber pads.
    • Remove twelve screws from the bottom of the laptop using a Phillips #0 screwdriver.
    • There are four different screw sizes.
  2. Asus Vivobook F510UA Hard Drive Replacement, Screws under the rubber feet: passo 2, imagem 1 %32 Asus Vivobook F510UA Hard Drive Replacement, Screws under the rubber feet: passo 2, imagem 2 %32
    • Remove the screws from beneath the rubber pads using a Phillips #0 screwdriver.
  3. Asus Vivobook F510UA Hard Drive Replacement: passo 3, imagem 1 %32 Asus Vivobook F510UA Hard Drive Replacement: passo 3, imagem 2 %32 Asus Vivobook F510UA Hard Drive Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    iFixit Opening Tool
    $1.99
  4. Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: passo 4, imagem 1 %32 Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: passo 4, imagem 2 %32 Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: passo 4, imagem 3 %32
    • For precautionary purposes, we advise that you disconnect the battery connector to avoid any electrical discharge.
    • Use plastic tools to avoid damaging the battery, which could leak dangerous chemicals or catch fire.
    • Using a fingernail or spudger, move back the retaining clip holding the battery connector in place.
    • The battery connector is very fragile. Proceed with caution.
    • Put a spudger under the battery connector and twist, to lift off the connector.
    • You may want to look at the battery disconnection steps for Asus Vivobook F412DA: Release battery connector, which are the same as for this model.
  5. Asus Vivobook F510UA Hard Drive Replacement: passo 5, imagem 1 %32 Asus Vivobook F510UA Hard Drive Replacement: passo 5, imagem 2 %32 Asus Vivobook F510UA Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the four screws from the hard drive using a Phillips #0 screwdriver.
    • Peel off the tape covering the end of the hard drive to reveal additional screws.
  6. Asus Vivobook F510UA Hard Drive Replacement: passo 6, imagem 1 %32 Asus Vivobook F510UA Hard Drive Replacement: passo 6, imagem 2 %32 Asus Vivobook F510UA Hard Drive Replacement: passo 6, imagem 3 %32
    • Hold the base of the hard drive tray and slide it out and away from its connector.
    • Remove the four Phillips #0 screws from the hard drive tray to free the drive.
    • Install the new drive into the tray, then slide the tray back into the laptop.
    • After inserting your new SSD, apply the thermal pad on top of the area where the connector is.
Conclusão
Deandre Mendes
Membro desde: 01/13/22
171 Reputação
Autoria de 1 guia
Equipe
Um comentário
Usually, the battery is disconnected before working on the internals of the laptop. While the battery itself is a different model, the instructions for removing the battery connector in Asus VivoBook 14-Inch F412DA Battery Replacement#Release the battery connector worked well for this laptop.
Sohum - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 1,856
