Ir para o conteúdo principal
Asus V6800V Wireless Card Replacement
Steven
Steven e 10 outros colaboradores
Última atualização em December 18, 2023
10 - 20 minutos
Moderada
Imagens inconsistentes
Use this guide to replace the Wi-Fi card in your Asus V6800V laptop.
A Wi-Fi card is a module that can receive or send data via Wi-Fi. It can be used to connect to the internet, a wireless router, or a smart device. It can be installed internally or externally on a PC, depending on the type and compatibility.
Before using the guide, try connecting to a network on a different frequency band. Many consumer Wi-Fi routers broadcast at two different network frequency bands: 2.4 GHz and 5 GHz. These will appear as separate networks in the list of available Wi-Fi networks. If your list of available Wi-Fi networks includes both a 2.4 GHz network and a 5 GHz network, try connecting to the other network. Also, try running network troubleshooting.
If the Wi-Fi in your laptop still isn’t able to connect to Wi-Fi networks, you need to replace it to let that happen. To do that you need to remove the charger and battery from the computer before beginning. For removing the battery, follow this guide.
O que você precisa
Ferramentas
  1. Asus V6800V Wireless Card Replacement, Battery: passo 1, imagem 1 %32 Asus V6800V Wireless Card Replacement, Battery: passo 1, imagem 2 %32
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: passo 2, imagem 1 %32 Asus V6800V Wireless Card Replacement, Wireless Card: passo 2, imagem 2 %32
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: passo 3, imagem 1 %32 Asus V6800V Wireless Card Replacement: passo 3, imagem 2 %32
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: passo 4, imagem 1 %32
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: passo 5, imagem 1 %32 Asus V6800V Wireless Card Replacement: passo 5, imagem 2 %32 Asus V6800V Wireless Card Replacement: passo 5, imagem 3 %32
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: passo 6, imagem 1 %32 Asus V6800V Wireless Card Replacement: passo 6, imagem 2 %32
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
Conclusão
Steven
Membro desde: 06/24/10
32 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-9, Johann Summer 2010 Membro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,890
