Asus G74SX-BBK7 Optical Drive Replacement
Introdução
Ir para o passo 1This guide will teach you how to replace the optical drive in your Asus. An optical drive is responsible for reading media discs like CDs and DVDs, so knowing how to replace it is important. If your computer won't properly read discs or is not functioning, you may need to replace the optical drive. This guide will give you the tools to do so.
O que você precisa
Peças
Ferramentas
Exibir mais…
Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
Take off the back panel.
4 outras pessoas executaram este guia.
