Apple Studio Display M7649 ADC Cable Replacement
Introdução
Ir para o passo 1Replacing the ADC cable. This cable provides connection to the computer, along with supplying power to the display.
O que você precisa
Ferramentas
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
To remove the USB port, remove these four screws holding down the port and metal brackets.
Remove these four screws holding down the base of the swing arm to the display and remove it
3 outras pessoas executaram este guia.
