Ir para o conteúdo principal
Amazon Kindle DX LCD Replacement
Lori White
Lori White e 9 outros colaboradores
Última atualização em 23 de set de 2024
10 - 30 minutos
Fácil
Faltando Passos
Introdução
Ir para o passo 1
This guide will show users how to replace the LCD screen on the Amazon Kindle DX in just a few simple steps.
Note: This guide is incomplete, the motherboard will need to be removed before the screen can be replaced.
O que você precisa
Ferramentas
Exibir mais…
  1. Amazon Kindle DX LCD Replacement, Liquid Crystal Display (LCD): passo 1, imagem 1 %32
    • Take your Kindle and place it screen side down in order to open it from the back. Use the opening tool from the ifixit tool kit and insert it between the metal casing and plastic top piece.
  2. Amazon Kindle DX LCD Replacement: passo 2, imagem 1 %32
    • Once enough pressure is applied the small piece will pop open.
  3. Amazon Kindle DX LCD Replacement: passo 3, imagem 1 %32
    • Remove the plastic piece.
  4. Amazon Kindle DX LCD Replacement: passo 4, imagem 1 %32 Amazon Kindle DX LCD Replacement: passo 4, imagem 2 %32
    • Once the small plastic piece is removed you will need to locate two 40mm screws on both corners of the remaining casing. Use the PH000 Philips Head Screwdriver from the tool kit to remove both screws.
  5. Amazon Kindle DX LCD Replacement: passo 5, imagem 1 %32
    • Use the opening tool again to take the off the bigger metal piece.
  6. Amazon Kindle DX LCD Replacement: passo 6, imagem 1 %32
    • Once the piece removed, locate the battery.
  7. Amazon Kindle DX LCD Replacement: passo 7, imagem 1 %32 Amazon Kindle DX LCD Replacement: passo 7, imagem 2 %32
    • Locate the two 30mm screws securing the battery on the bottom of the Kindle DX. Use the PH00 Philips head screw driver from the tool kit to remove both screws.
  8. Amazon Kindle DX LCD Replacement: passo 8, imagem 1 %32 Amazon Kindle DX LCD Replacement: passo 8, imagem 2 %32
    • Take the battery off once the screws have been removed.
  9. Amazon Kindle DX LCD Replacement: passo 9, imagem 1 %32 Amazon Kindle DX LCD Replacement: passo 9, imagem 2 %32
    • Unscrew the 30 mm screws using a Phillips #000 screwdriver as shown in the picture.
  10. Amazon Kindle DX LCD Replacement: passo 10, imagem 1 %32 Amazon Kindle DX LCD Replacement: passo 10, imagem 2 %32
    • Unscrew the 30 mm screws using a Phillips #000 screwdriver as demonstrated in the picture.
  11. Amazon Kindle DX LCD Replacement: passo 11, imagem 1 %32
    • Remove the black case to reveal the mother board.
    The back case will still be attached to the motherboard here because the two speaker wires are still connected. You made no mention of removing the speaker wires? These connectors are small and stubborn while removing.
    airshack - Responder
  12. Amazon Kindle DX LCD Replacement: passo 12, imagem 1 %32
    • Remove the motherboard from the display assembly.
Conclusão
Gear Up For Future Repairs
Shop all
Lori White
Membro desde: 09/28/16
577 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-5, Cagle Fall 2016 Membro de USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 Membros
Autoria de 10 guias
3Comentários do guia
Guide is incomplete :(
Robert Rogers - Responder
I can follow and understand up to step 11.
Steps 12 and 13 loose me, why would one need to remove the metal protection lid / shield? There does not seem to be any screws covered by the lids that need to be removed.
one would need to unclip the screen from the motherboard the lead off board from the wireless card to aerial and unscrew the remaining motherboard screws at least before you could remove the motherboard to access the screen to replace it.
Terry Mummery - Responder
Guide is useless and should be removed or replaced.
golan.benoni - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 3,729
