Ir para o conteúdo principal
Alcatel One Touch Evolve 2 LCD Screen Replacement
Akira Nakaza
Akira Nakaza e um outro colaborador
Última atualização em August 17, 2021
20 minutos
Moderado
Introdução
Ir para o passo 1
This guide will provide the necessary steps to replace the LCD screen from the Alcatel OneTouch Evolve 2.
O que você precisa
Ferramentas
Exibir mais…
  1. Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: passo 1, imagem 1 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: passo 1, imagem 2 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: passo 1, imagem 3 %32
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 3, imagem 1 %32
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 4, imagem 1 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 4, imagem 2 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 4, imagem 3 %32
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 5, imagem 1 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 5, imagem 2 %32
    • Pull the rear frame off with your hands.
  6. Alcatel One Touch Evolve 2 LCD Screen Replacement, Main Circuit Board: passo 6, imagem 1 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement, Main Circuit Board: passo 6, imagem 2 %32
    • Use a plastic opening tool to pop the speaker press-fit connector free.
    • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
  7. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 7, imagem 1 %32
    • Use a plastic opening tool to lift the front camera press-fit connector free.
  8. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 8, imagem 1 %32
    • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
  9. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 9, imagem 1 %32
    • Detach the main circuit board from the front cover.
  10. Alcatel One Touch Evolve 2 LCD Screen Replacement, LCD Screen: passo 10, imagem 1 %32
    • Gently pry off the digitizer from the main circuit board using a spudger
  11. Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 11, imagem 1 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 11, imagem 2 %32 Alcatel One Touch Evolve 2 LCD Screen Replacement: passo 11, imagem 3 %32
    • Carefully separate the digitizer from circuit board.
    • Using your hands, gently remove the ribbon connecting the digitizer to the circuit board.
Conclusão
Akira Nakaza
Membro desde: 11/08/17
427 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G5, Baechle Fall 2017 Membro de IUPUI, Team S5-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G5
3 Membros
Autoria de 6 guias
1Comentário do guia
Merci de nous donner l’équivalant de numériseur d'écran tactile pour Alcatel One Touch Evolve 2 4037T,l’origine est obsolète.
salut
labadi.abdelmalek - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 1,151
