Ir para o conteúdo principal
Alcatel Go Flip V Flip Phone Screen Replacement
Jerry Wheeler
Jerry Wheeler e um outro colaborador
Última atualização em January 9, 2024
Nenhuma estimativa
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
The front and rear screens are fused into a single assembly and cannot be replaced individually. This guide will show how to replace the complete assembly.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Screen Cover: passo 1, imagem 1 %32
    • Heat the screen cover with an iOpener, a heat gun or even a hair dryer to soften the adhesive holding it to the display frame.
    • Use caution with a heat gun as you could easily melt the plastic screen cover.
  2. Alcatel Go Flip V Flip Phone Screen Replacement: passo 2, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 2, imagem 2 %32
    • Insert a curved razor blade under the screen cover to pry it open.
  3. Alcatel Go Flip V Flip Phone Screen Replacement: passo 3, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 3, imagem 2 %32
    • Use plastic picks to separate the adhesive. Metal is not advised as it will scratch the plastic material the cover is made of. Add more heat as needed.
  4. Alcatel Go Flip V Flip Phone Screen Replacement: passo 4, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 4, imagem 2 %32
    • Remove the plastic screen cover.
  5. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Rear Cover: passo 5, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Rear Cover: passo 5, imagem 2 %32
    • Remove the four 3.5mm Phillips screws holding the rear cover in place.
  6. Alcatel Go Flip V Flip Phone Screen Replacement: passo 6, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 6, imagem 2 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 6, imagem 3 %32
    • Starting at the hinge side, insert a metal opening tool between the rear cover and the display's frame.
    • Continue down the side of the phone, releasing clips as you go.
  7. Alcatel Go Flip V Flip Phone Screen Replacement: passo 7, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 7, imagem 2 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 7, imagem 3 %32
    • Work your way across the bottom and up the other side.
    • And finally the rear cover is free.
  8. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Camera: passo 8, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement, Remove the Camera: passo 8, imagem 2 %32
    • Using a spudger, disconnect the camera's flex cable.
  9. Alcatel Go Flip V Flip Phone Screen Replacement: passo 9, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 9, imagem 2 %32
    • Remove the camera from the display.
  10. Alcatel Go Flip V Flip Phone Screen Replacement, Screen: passo 10, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement, Screen: passo 10, imagem 2 %32 Alcatel Go Flip V Flip Phone Screen Replacement, Screen: passo 10, imagem 3 %32
    • Unplug the display connector.
  11. Alcatel Go Flip V Flip Phone Screen Replacement, Slice the Adhesive: passo 11, imagem 1 %32
    • The screen is held onto the display frame with adhesive around the outside edge of the LCD, with a thicker bar of adhesive along the bottom edge as shown.
  12. Alcatel Go Flip V Flip Phone Screen Replacement: passo 12, imagem 1 %32
    • Heat the edges of the LCD frame to soften the adhesive holding it in place. A hair dryer, heat gun or iOpener will all work fine.
  13. Alcatel Go Flip V Flip Phone Screen Replacement: passo 13, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 13, imagem 2 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 13, imagem 3 %32
    • Insert an opening tool between the lip of the frame and the LCD. Use it to slice the adhesive along the top edge.
    • Now go along the side edge.
  14. Alcatel Go Flip V Flip Phone Screen Replacement: passo 14, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 14, imagem 2 %32
    • Then along the other side.
  15. Alcatel Go Flip V Flip Phone Screen Replacement: passo 15, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement: passo 15, imagem 2 %32
    • Finally, slice the adhesive along the bottom edge. Note that you'll need to go much deeper as there is a wider strip of adhesive along that edge.
  16. Alcatel Go Flip V Flip Phone Screen Replacement, Dismount the Vibrator: passo 16, imagem 1 %32
    • The vibrator is lightly glued to the display frame. Gently pry it loose, mindful of the wires attaching it to the LCD assembly.
  17. Alcatel Go Flip V Flip Phone Screen Replacement, Remove the LCD Assembly: passo 17, imagem 1 %32 Alcatel Go Flip V Flip Phone Screen Replacement, Remove the LCD Assembly: passo 17, imagem 2 %32
    • Lift the LCD assembly from the display frame. There will probably be several strands of adhesive you'll need to separate as you pull it apart.
Conclusão
Uma outra pessoa concluiu este guia.
Jerry Wheeler
Membro desde: 03/21/22
73.355 Reputação
Autoria de 71 guias
Equipe
Oregonians Membro de Oregonians
Community
8 Membros
Autoria de 191 guias
2Comentários do guia
Where can I get a replacement screen?
Aiden Ventura - Responder
I wasn't able to locate a supplier for new or used replacement parts so I ended up buying one on eBay that had broken hinges and was being sold for parts.
If you have better luck, let us know.
Jerry Wheeler -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 885
