Ir para o conteúdo principal
Acer Nitro 5 AN515-53-52FA Fan Replacement
Alfredo Prieto
Alfredo Prieto e 4 outros colaboradores
Última atualização em February 28, 2023
30 - 55 minutos
Moderada
Use this guide to replace the fan in the Acer Nitro 5 AN515-53-52FA, before using this guide open up the computer and use a can of air on the fan.
The fan is the cooling unit of the laptop, without the fans the laptop would not cool and overheat. A broken fan can make uncommon noises, and ruin the performance of the laptop. Dirt or dust could get lodged into the fan forcing them to stop and overheat the laptop.
The Old fans of the laptop can easily be recycled after.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Acer Nitro 5 AN515-53-52FA Fan Replacement, Fan: passo 1, imagem 1 %32
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up
  2. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 3, imagem 2 %32
    • Use a plastic opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
    • Removing the backshell of the laptop will reveal the inside of it.
    • The fan of the laptop is located on the top left of the laptop.
  4. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the four 9 mm screws securing the fans.
  5. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, imagem 2 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, imagem 3 %32
    • Unplug the connectors before taking the fan out.
  6. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 6, imagem 2 %32
    • Gently remove the fans from the adhesive strip.
Conclusão
6 outras pessoas executaram este guia.
Alfredo Prieto
Membro desde: 09/01/22
908 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-3, Pee Fall 2022 Membro de Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
Membros da 4
Autoria de 7 guias
2 comentários
This helped me out. The instructions were completely easy to follow. Thank you so much!
Adam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 64
Duração total: 1,447
