Acer Chromebook CB3-131-C3KD Motherboard Replacement
Introdução
Ir para o passo 1Use this guide to replace the motherboard for your device.
O que você precisa
Ferramentas
Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
Unscrew the (4) four J0 head 3.0 mm screws from the motherboard.
Unscrew the (1) one 7.0 mm screw from the center of the motherboard.
