Ir para o conteúdo principal
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
Avinesh Mohanaranjan
Avinesh Mohanaranjan e um outro colaborador
Última atualização em July 18, 2022
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Situations where your Chromebook is unable to display wireless settings or is experiencing dropped connections, is commonly a sign that your Wi-Fi card in the device is faulty and needs to be replaced. This guide will walk you through replacing the Wi-Fi card in your Acer Chromebook 15 CB3-532-C6T1.
Prior to beginning the repair, be sure your Chromebook is powered off and is not plugged into the wall charger.
O que você precisa
Ferramentas
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 1 %32
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 3, imagem 1 %32 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 5, imagem 1 %32 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 6, imagem 1 %32 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 6, imagem 2 %32 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: passo 6, imagem 3 %32
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
Conclusão
Membro desde: 09/16/21
183 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 959
