Acer Aspire One ZG5 Internal Wireless Card Replacement
Introdução
Vá para o passo 1After removing the top case, it is easy to get to the internal wireless card.
O que você precisa
Ferramentas
Turn the netbook upside down with the battery at the top, facing away from you.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Gently lift up the left side of the wireless card and slide the card out of its socket.
Turn the netbook over and open the display so that the keyboard is facing you.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
5 outras pessoas executaram este guia.
