Acer Aspire E3-111-C0WA Hard Drive Replacement
Introdução
Ir para o passo 1If your hard drive needs replacement or upgrading, use this guide to remove your old storage device and install a new one.
O que você precisa
Ferramentas
Exibir mais…
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
