Ir para o conteúdo principal
Acer Aspire 8735G Memory (RAM) Replacement
Regome
Regome e 2 outros colaboradores
Última atualização em April 23, 2024
5 - 10 minutos
Fácil
Pontos lista!
Guia colaborativo
O que você precisa
Ferramentas
  1. Acer Aspire 8735G Memory (RAM) Replacement, Battery: passo 1, imagem 1 %32
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Memory (RAM) Replacement: passo 2, imagem 1 %32
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Memory (RAM) Replacement: passo 3, imagem 1 %32
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Memory (RAM) Replacement: passo 4, imagem 1 %32
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Acer Aspire 8735G Memory (RAM) Replacement, RAM: passo 5, imagem 1 %32
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws. After that you are in.
  6. Acer Aspire 8735G Memory (RAM) Replacement: passo 6, imagem 1 %32
    • Now try to spot the Memory, which is here indistinguishable as a red circle.
  7. Acer Aspire 8735G Memory (RAM) Replacement: passo 7, imagem 1 %32
    • Don't remove the ram before pushing the pins.
    • After the previous step, remove the ram by pushing the pins holding it outwards.
  8. Acer Aspire 8735G Memory (RAM) Replacement: passo 8, imagem 1 %32
    • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
    • After that the pins jump up and you can carefully remove the ram.
Conclusão
Uma outra pessoa concluiu este guia.
Regome
Membro desde: 01/20/23
794 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 155
