Introdução
Before replacing the LCD module, make sure to back up your laptop.
O que você precisa
Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
Ferramenta utilizada nesse passo:Tweezers$4.99
Remove the white antenna of the wireless module.
Use the Phillips #1 screwdriver to remove the two 6.5mm Phillips #1 screws.
Use the Phillips #1 screwdriver to remove the three 4.5mm Phillips #1 screws.
Uma outra pessoa concluiu este guia.
