Ir para o conteúdo principal
Acer Aspire 5734z-4836 Keyboard Replacement
Holly Steininger
Holly Steininger e 5 outros colaboradores
Última atualização em July 26, 2018
3 minutos
Fácil
Introdução
Ir para o passo 1
The keyboard replacement is a simple replacement guide, but to remove the panel some force may be necessary.
  1. Acer Aspire 5734z-4836 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire 5734z-4836 Keyboard Replacement: passo 3, imagem 2 %32
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire 5734z-4836 Keyboard Replacement: passo 5, imagem 2 %32
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire 5734z-4836 Keyboard Replacement: passo 6, imagem 2 %32 Acer Aspire 5734z-4836 Keyboard Replacement: passo 6, imagem 3 %32
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
Conclusão
Holly Steininger
Membro desde: 09/12/16
258 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-3, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,536
