Acer Aspire 5542G keyboard, top case Replacement
Introdução
Ir para o passo 1This guide is short photo-tutorial on how to swap the keyboard and top case of Acer Aspire 5542g
O que você precisa
Remove all screws on the bottom of laptop. Remove HD cover (it's not necessary to remove battery and RAM cover)
3 outras pessoas executaram este guia.
3Comentários do guia
Hi,
if you have old keyboard at least partially working, try to put it back. If it works. probably the problem is with the new keyboard.
If the old one also doesn't work, the problem is probably with motherboard connector or software (less probable). To check the software problem, i think it's possible to load the laptop from any linux live cd or some other OS different from what s installed on your pc.
Please be aware i'm not professional pc service man and these are just common thoughts (hope helpful)
Battery death solution please
