Ir para o conteúdo principal
Acer Aspire 5542G keyboard, top case Replacement
leonid
leonid e 2 outros colaboradores
Última atualização em July 2, 2014
1 hora
Fácil
Fotos de ação
Precisa de melhores imagens
Acidente de Marcação
Guia colaborativo
This guide is short photo-tutorial on how to swap the keyboard and top case of Acer Aspire 5542g
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Acer Aspire 5542G keyboard, top case Replacement, keyboard, top case: passo 1, imagem 1 %32
    • Remove all screws on the bottom of laptop. Remove HD cover (it's not necessary to remove battery and RAM cover)
  2. Acer Aspire 5542G keyboard, top case Replacement: passo 2, imagem 1 %32 Acer Aspire 5542G keyboard, top case Replacement: passo 2, imagem 2 %32
    • Using plastic openning sticks pick and move up top cover-panel. After disconnectiong all cables put it away.
  3. Acer Aspire 5542G keyboard, top case Replacement: passo 3, imagem 1 %32 Acer Aspire 5542G keyboard, top case Replacement: passo 3, imagem 2 %32
    • Raise the keyboard a little (slightly bending in order to free its plastic fixtures from the base case). Before putting the key board completely out, disconnect its flat cable from the motherboard.
  4. Acer Aspire 5542G keyboard, top case Replacement: passo 4, imagem 1 %32 Acer Aspire 5542G keyboard, top case Replacement: passo 4, imagem 2 %32 Acer Aspire 5542G keyboard, top case Replacement: passo 4, imagem 3 %32
    • In order to make the top case free remove the screen screws and unplug its cables:
    • 1. remove two side screws
    • 2. unplug the connector at the bottom of the screen
    • At the bottom of laptop unplug two coax cables which pierce top case and mother board
  5. Acer Aspire 5542G keyboard, top case Replacement: passo 5, imagem 1 %32
    • Now the top case is free to move. Detach it from the base help yourself with plastc openning sticks (don't forget to unplug flat cables).
  6. Acer Aspire 5542G keyboard, top case Replacement: passo 6, imagem 1 %32
    • Install new top case and kewboard. Assemble all parts in reversed order.
Conclusão
3 outras pessoas executaram este guia.
leonid
Membro desde: 03/11/14
245 Reputação
Autoria de 1 guia
3 comentários
Hello, after completing it and turning on my notebook, the keyboard do not work. Do you know where the problem can be?
Vadja - Responder
Hi,
if you have old keyboard at least partially working, try to put it back. If it works. probably the problem is with the new keyboard.
If the old one also doesn't work, the problem is probably with motherboard connector or software (less probable). To check the software problem, i think it's possible to load the laptop from any linux live cd or some other OS different from what s installed on your pc.
Please be aware i'm not professional pc service man and these are just common thoughts (hope helpful)
leonid - Responder
Battery death solution please
youssef benzyane - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 5,042
