Ir para o conteúdo principal
Acer Aspire 5534-1096 Battery Replacement
Muzzamil Mirza
Muzzamil Mirza e 4 outros colaboradores
Última atualização em December 30, 2019
1 minuto
Muito fácil
Introdução
Ir para o passo 1
A battery is utilized for the electric current, or energy, required operate the device. The nickel metal hydrate battery stores electric charge through a chemical reaction when current is conducted through the electrodes. The ability of the battery to carry charge diminishes as matter decays (i.e. half-life) through its normal use and lifetime. The guide will demonstrate how to replace an Acer Aspire 5534-1096 battery.
  1. Acer Aspire 5534-1096 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Disconnect laptop from electric source prior to any repair.
    • On the bottom side of the laptop, you will unlock the safety lock by sliding it towards the left.
  2. Acer Aspire 5534-1096 Battery Replacement: passo 2, imagem 1 %32
    • Now, you'll hold this latch to the left. Everything is unlatched. The battery should feel free.
  3. Acer Aspire 5534-1096 Battery Replacement: passo 3, imagem 1 %32 Acer Aspire 5534-1096 Battery Replacement: passo 3, imagem 2 %32 Acer Aspire 5534-1096 Battery Replacement: passo 3, imagem 3 %32
    • While continuing to hold the latch in the open position, use your other hand to push the battery away from the device to remove it.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 378
