Acer Aspire 5 A515-54 Hard Drive Replacement
Introdução
Ir para o passo 1This guide will show you how to replace or upgrade your Acer Aspire 5 A515-54 hard drive. The HDD is used for storing operating systems, software programs and other files.
Before proceeding with the replacement, it is highly recommended to back up any important and necessary files in order to prevent any data loss. You should also power off your laptop and unplug from any power source prior to beginning this repair.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Turn off and unplug your Acer Aspire 5 A515-54.
Flip it over so the backside is facing up.
After replace and install the new hard drive to the laptop, you need to format the new drive and that's it. You have upgraded the hard drive of your laptop.
2 comentários
I currently have a 256gb ssd in my Acer Aspire 5 A515-54. I would like to upgrade to a 1TB ssd and this guide is great but how can I transfer the data to the new ssd?
Try using a hdd cloning software.
