Ir para o conteúdo principal
ACER Aspire 7750G-6645 Fan Replacement
taylan ergil
taylan ergil e 5 outros colaboradores
Última atualização em March 7, 2024
25 - 40 minutos
Difícil
Precisa de mais images
Faltando Passos
This is a replacement guide for the internal cooling fan of a Acer Aspire 7750G-6645. This guide may be helpful if the fan starts to make loud noises or if the computer starts to heat up too much too fast.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. ACER Aspire 7750G-6645 Fan Replacement, Keyboard: passo 1, imagem 1 %32 ACER Aspire 7750G-6645 Fan Replacement, Keyboard: passo 1, imagem 2 %32
    • Turn off the laptop, and open the lid.
    • Separate the first two layers by prying them apart, using a spudger.
  2. ACER Aspire 7750G-6645 Fan Replacement: passo 2, imagem 1 %32 ACER Aspire 7750G-6645 Fan Replacement: passo 2, imagem 2 %32 ACER Aspire 7750G-6645 Fan Replacement: passo 2, imagem 3 %32
    • Lift the keyboard, so that its ribbon is visible.
    • Remove the ribbon from the board by using a small metal spudger or flathead screwdriver. (if needed)
  3. ACER Aspire 7750G-6645 Fan Replacement, Fan: passo 3, imagem 1 %32 ACER Aspire 7750G-6645 Fan Replacement, Fan: passo 3, imagem 2 %32
    • Remove the two 3mm screws using the Phillips #00 screwdriver.
    • Remove the two 6mm screws using the same screwdriver.
    • Remove the fan cover to gain access to the fan.
  4. ACER Aspire 7750G-6645 Fan Replacement: passo 4, imagem 1 %32 ACER Aspire 7750G-6645 Fan Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Lift the fan up and away from the device. Do not remove the fan from the device.
    • Desolder the attached part using a Soldering Iron to heat it up and remove the leftover heated lead by using a Desoldering Pump.
    • If you aren't familiar with soldering, read our How to Solder and Desolder Connections guide for more information.
Conclusão
taylan ergil
Membro desde: 03/08/19
85 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 20
Duração total: 723
