Ir para o conteúdo principal
2013 Nissan Rogue Key Fob Battery Replacement
Homero Mena Ortiz
Homero Mena Ortiz e um outro colaborador
Última atualização em June 14, 2022
10 minutos
Fácil
Introdução
Ir para o passo 1
Is your 2013 Nissan Rogue Key Fob not working properly, or isn't working at all? It might be time to replace the battery, and while it's open, take the time to clean out the inside.
Fob batteries needs to be replaced every 3 years to work at maximum range and not sporadically fail.
This guide demonstrates how to replace the battery and clean out your 2013 Nissan Rogue Key Fob.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: passo 1, imagem 1 %32 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: passo 1, imagem 2 %32
    • Slide the small tab on the back of your fob to the left.
    • While holding the tab to the left, pull the metal key out from the top of your fob.
  2. 2013 Nissan Rogue Key Fob Battery Replacement: passo 2, imagem 1 %32
    • Insert your opening pick into the small gap between the two halves of the fob and lightly pry until they separate.
  3. 2013 Nissan Rogue Key Fob Battery Replacement: passo 3, imagem 1 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 3, imagem 2 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 3, imagem 3 %32
    • Pull the two halves of the fob apart.
    • Remove the two internal housings.
  4. 2013 Nissan Rogue Key Fob Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery.
  5. 2013 Nissan Rogue Key Fob Battery Replacement: passo 5, imagem 1 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 5, imagem 2 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 5, imagem 3 %32
    • Lightly saturate a cotton swab with 70% isopropyl alcohol and wipe down the inside of the shells and the rubber pad.
    • For any small crevices dip, the toothpick into the alcohol and clean any dirt or debris.
    • Avoid wiping the circuit board and any metal components.
  6. 2013 Nissan Rogue Key Fob Battery Replacement: passo 6, imagem 1 %32
    • Once the alcohol is dried, place a new battery into the battery housing with the proper orientation.
  7. 2013 Nissan Rogue Key Fob Battery Replacement: passo 7, imagem 1 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 7, imagem 2 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 7, imagem 3 %32
    • Replace the internal components and click the two halves of the fob back together.
  8. 2013 Nissan Rogue Key Fob Battery Replacement: passo 8, imagem 1 %32 2013 Nissan Rogue Key Fob Battery Replacement: passo 8, imagem 2 %32
    • Slide your key back into its housing.
Conclusão
Your fob should now be fully functional!
Uma outra pessoa concluiu este guia.
2Comentários do guia
OMG… I wish I had read this before and attempted to take my key fob apart. I’ve got it all scraped up and ugly from them telling me to use a screwdriver….never mind just do exacty everything this post tells you. I had no problems opening the key fob once I read this article .
Trust me do as this tells you step by step. Just don’t use a screwdriver as another on the www will inform you to do.
Thank you so much for posting this key fob battery replacement info.
Pamela Parker - Responder
Thanks worked perfectly and as stated above don't use a screwdriver I also read that but thank goodness I didn't have one
brandy france - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 88
Ao todo: 4,950
