Ir para o conteúdo principal
Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
20 Perguntas Visualizar todos
Screen brightness is low
My phone has low brightness even when adaptive brightness is off and brightness level is at maximum.how can I fix this problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If the Samsung Galaxy A13 brightness for the screen is not high, even at maximum settings, here are some potential solutions:
Increase Brightness Manually
Head to Settings > Display > Brightness and bump it up all the way.
If it is enabled, turn off Adaptive Brightness.
Turn Off Power Saving Mode
Go to: Settings > Battery and Device Care > Battery > Power Saving Mode
Disable it if the option is turned on because it lowers the brightness level of the screen.
If Possible, See if You Can Turn Off the Blue Light or the Extra Dim Mode
ж Settings > Display > Eye Comfort Shield
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Keoagile chad Monyatsi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 13
Ao todo: 33
