Ir para o conteúdo principal
Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
New battery won’t charge
New battery 🪫 is showing 1% and the display symbol is a red bolt indicator. Watch charges fine with old battery. Watch reset just fine but it will not charge properly. Constant rebooting on the new dead battery.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Similar problem here: new battery. Watch still doesn't show signs of life. Gets hot while charging. Nothing on display after trying all button combination.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
When you connect the puck onto the watch does it even respond?
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yes the red circle bolt turns on
por
@joemech83 - Jump to Step 14 in this guide Apple Watch Series 6 Battery Replacement double check the connection, is the connection firm, could one of the contacts or the cable damaged? Otherwise you’ll need to get a replacement battery.
por
Adicionar a sua resposta
Joemech83 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 48
