Ir para o conteúdo principal
Released in 2014, Dyson's AM09 is a bladeless fan-heater combo. It comes with a remote for easy control.
7 Perguntas Visualizar todos
not work on hot mod for long time
This devise has broken body. I tried to control the certain temperature in hot mode but it not stay remain at that temperature and automatically shift certainly to the cold mode and start to throw the cold blow of air.
To maintain the temperature I tried different temperature option by run it low and high temperature but it did not work.
Even I do not have its remote control so I can not control it by remote. At the medium temperature it was run for some more time but it not stay on that mode.
On the start the display shows the certain temperature and when it throw cold blow (turn the mode) it shows the "H2" on the display and the bouton will not gave any response in that mode I have to turn it off from the switch board.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Reviewed questions in the box to the right of this page for help? If not answered then your unit may be dirty internally and would need to be disassembled carefully to clean it. Electronic temperature sensors are one form of safety to prevent a fire hazard from overheating. There are no guarantees of success here as there may be damage in electronics.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Patel Het será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 55
