Ir para o conteúdo principal
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
20 Perguntas Visualizar todos
Circle pad replacement not moving freely
I replaced the circle pad on my 3ds xl and the new one doesn't move freely
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi There!
So, which one did you replaced? The rubber one or the circle pad part?
If you did replaced the circle pad it self, make sure that you calibrated it correctly on the 3DS it self. If this didn't fixed it, then return it and get yourself a new one.
If it's the rubber, make sure that it's inserted correctly. Also, make sure that the plastic rings are placed back as it was before! Otherwise it could cause the issue you are having.
Otherwise, replace the plastic rings.
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
I replaced the circle pad. I noticed that the new one has a slight dent and the old one doesn't and I think that is what stops it from moving freely
por
Alright, if you are sure that the plastic rings are placed correctly (and aligned correctly), then you probably need to return the Circle Pad.
por
Adicionar a sua resposta
Jairo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 40
