Ir para o conteúdo principal
Why some keys not working?
Some keys such as setting not working. How can I fix them?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Start by cleaning the keyboard. Then remove the power for a few minutes and re-power.
If that doesn't fix it, you likely have a defective keyboard.
However, it could also be a component on the main board.
If the kbd is part of the main board, replace. If the kbd is plugged into the main board, then it is a guessing game as to which one to replace first.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Max Hamidi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 14
