Ir para o conteúdo principal
The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
Turning on automaticity when charging
Hey there, so my quest 2 is having a issue where whenever it’s plugged in to charge it will power back on, I have tried everything to troubleshoot shoot and think it’s a technical issue was wondering if you ever seen this before or know how to fix it
I have swapped the proximity sensor with a good one to see if that was it bc I thought it could be but nope still same issue
Only other thing I could possibly think is the usb charger port/cable but I’m not a pro when it comes to small device repairs so don’t wanna risk it without more details and testing
Idk how this question works but if needed my email is tntn3rd@gmail.com
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Yes it is fully powered off and no it is not the charger cable
I have two quests and only one has this issue
(It isn’t a user issue)
por
Does it actually fully turn on?
por
Adicionar um comentário
2 respostas
Solução escolhida
After trouble shooting for a while and trying everything from the most basic fixes to complicated ones I was able to fix it
I had to replace the charger/port flex cable to fix the issue and to clarify I don’t mean the charger cable I mean the flex cable inside of the headset it self so I took it apart and replaced it with a new one
Sure this wasn’t a huge issue bc the headset was fully functional but it was an issue nonetheless and I have OCD so I had to fix it for the life of me lol
Esta resposta foi útil?
Pontuação 0
Is the oculus fully powered off, or is it in sleep mode?
Pontuação 0
1 comentário:
Yes it is fully powered off, the issue had to do with the power cable
por
Adicionar a sua resposta
TnTN3Rd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 50
