Ir para o conteúdo principal
The Black+Decker LSW20 is a 20-Volt Lithium-Ion Cordless Leaf Sweeper designed for clearing debris from hard surfaces such as patios, decks, and walkways, featuring a single-speed motor with an airspeed of 120 mph and weighing 3.7 pounds.
1 Perguntas Visualizar todos
Grinding noise when turning off
Why does my leaf blower grind when turning if off?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Well I had a black and decker shop vac that did that and I progressively got worse so I drilled a tiny hole to where the main bearings are injected grease and oil mixture and got another 6 months out of it. Personally I think it's a bad design anytime bearings run dry. But who knows water or dirt may have accelerated the problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
QuartzNCoal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 28
