Ir para o conteúdo principal
The DJI Mini 2 SE, The base model version of the previous Mini 2. With 2.7K video recording, it’s a great drone for beginners.
Gimbal Vibration Mount Replacement
Does anyone know how to replace the gimbal vibration mount? There are like no guides on how to disassemble the actual gimbal
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Not familiar with drones but did find this teardown for you.
https://www.fictiv.com/articles/dji-mini...
Also a selection of videos describing several components on mini 2 that may be similar to the mini 2 se.
https://forum.dji.com/thread-293492-1-1....
This link has individual YouTube videos for each of the component parts separately.
Hope this helps
Esta resposta foi útil?
Pontuação 0
3 comentários:
It’s more the actual gimbal assembling need to disassemble as the top mount had snapped completely and it didn’t get the refresh plan like an idiot. I’m used to doing smartphone repairs and it seems like a simple fix however there are no guides on how to disassemble it
por
Hi, this is the closest I could find for gimbal disassembly.
https://m.youtube.com/watch?v=O8ScD29nkN...
It covers disassembly of the gimbal for wire replacement and hopefully it’s enough to get you in a position to either replace the housing or be able to glue it with gorilla glue.
por
Helpful Harry, yes you are correct, Mini 2 and Mini 2 SE are pretty nuch the same.
por
Adicionar a sua resposta
DomTerra será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 48
Ao todo: 179
